11 years agoNeed Help to Verify Timing Constraints On Output Pins to External Device
Hi, I'm relatively new in FPGA designing, so forgive me if my question seem simple. The project I am working on involves using a Cyclone V to control 4 external DDS chips (AD9915). So I'...
11 years agoRsyc,
Let's assume another simple example where I have such a design: (picture taken from Quartus 2 TimeQuest Timing Anlayzer CookBook pg 1-16 on System Synchronous Output constraints) or even like the picture you have in your TimeQuest user guide pg 16. https://www.alteraforum.com/forum/attachment.php?attachmentid=10165 The design is just a register that is connected to an output port that is connected to an external device. in my SDC, should'nt it be just these following steps: 1) create clock for the clock input 2) create virtual clock for the external device 3) and then set otuput delay max and min to 0 ns (simple case) However I have setup a test module with the above description ( a reg to an output) and constrain the input clock to be 156.25 MHz. Even then, TimeQuest still reports that the design can't meet setup timing.
