11 years agoNeed Help to Verify Timing Constraints On Output Pins to External Device
Hi, I'm relatively new in FPGA designing, so forgive me if my question seem simple. The project I am working on involves using a Cyclone V to control 4 external DDS chips (AD9915). So I'...
11 years ago --- Quote Start --- 0ns external delay doesn't mean no IO requirement, just that the external device isn't chewing up any of the requirement. . --- Quote End --- it is not 0ns external delay. it is 0ns set_output_delay which according to sdc standards is defines as follows: max value = tSU of external device + board delay min value = negative of tH + external delay so if tSU and tH are zero, what does it mean to you? If that isn't the case then why sdc gives such definitions and equations
