11 years agoNeed Help to Verify Timing Constraints On Output Pins to External Device
Hi, I'm relatively new in FPGA designing, so forgive me if my question seem simple. The project I am working on involves using a Cyclone V to control 4 external DDS chips (AD9915). So I'...
11 years agosince you have set output delays to zero then it means no io requirement.
I believe the negative slack is inside fpga paths , not io
