11 years agoneed help in changing the deay in SYSRESET block in Igloo-2 device implementation
Hi, in one of our project we are using igloo2 device in which we are using "SYSRESET" block for reset deglitching.by default the out put delay is set to 10ps in the library,by chaning the veril...
11 years agoHi,
thanks for ur reply. in Igloo2 device it is recommended to use SYSRESET block to deglitch the reset signal. SYSRESET block is generating reset output if and only if input reset is active for minimum 10ps.In my board v want to consider the reset as valid only if it is active for 500ps.so finding out ways to change the deglitch parameter
