15 years agoNeed help capturing HSync (resolution)
I am having big problems trying to capture how many H Sync and how many V Sync occurs during the receive of DVI signal from the PC to my FPGA. Here is a sample of my code trying to COUNT how many H Sync were received during ONE second: library IEEE; use IEEE.STD_LOGIC_1164.ALL; use ieee.std_logic_unsigned.all; entity HorizontalCounter is port( HSync : IN STD_LOGIC; pulse : in std_logic; HCount : out STD_LOGIC_VECTOR( 31 downto 0) ); end HorizontalCounter; architecture a of HorizontalCounter is signal H_Counter : STD_LOGIC_VECTOR( 31 downto 0); begin process(HSync,pulse) begin if( pulse = '1') then H_Counter <= (others=>'0'); elsif (HSync'event and HSync = '1' ) then H_Counter <= H_Counter + 1; end if; end process; HCount <= H_Counter; end a; The 'Pulse' here is a signal that is high every one second and then goes to low. I was expecting the HCount to output how many HSync per second (might be a multiplied by 60) but the out put actually is 4, 8 or 6 depending on the resolution of the PC that feeds the signal in. I also failed to capture the number of how many VSync per second. I am trying simply to "Dynamically DETECT" the incoming resolution. Which also helps me to know when to capture a LINE and process it and when to retransmit it. Can you please help! Thanks.No RepliesBe the first to reply
