14 years agoNCO reset_n
Quartus II v12.0, Cyclone III, NCO v12.0, Small ROM, no modulation, no dithering, no hopping, 16-bit sine and cosine outputs, 24MHz clock: Nco_ug.pdf says reset_n is an active-low asynchronous re...
14 years ago --- Quote Start --- Is reset_n actually synchronous? --- Quote End --- No, the documentation is wrong in this regard. As far as I'm aware of, the NCO reset is mostly synchronous and partly asynchronous. A usual synchronously released reset should cause no problems.
