14 years agoNCO reset_n
Quartus II v12.0, Cyclone III, NCO v12.0, Small ROM, no modulation, no dithering, no hopping, 16-bit sine and cosine outputs, 24MHz clock: Nco_ug.pdf says reset_n is an active-low asynchronous re...
14 years agoIt could be you are releasing the reset as such or you are pre-synchronising it and that is good. If not then the outputs themselves are not under reset but some other internal nco logic e.g. accummulator.
