17 years agoNCO 8.1 Problem
HI, no matter what output freq. I set my NCO to have it is always coming out at 20 Mhz, or this is what I am measuring on the scope. I don't think this was happening when i was using quartus 6....
17 years agoI think that your problem is with the phi_inc_i then
This input is responsible for the NCO output frequency The mega wizard only shows you the value you should set the phi_inc_i, but it doesn't effectively change the frequency In the thread http://www.alteraforum.com/forum/showthread.php?t=3895 you can find some information on how this works You must set the phi_inc_i with the value shown on the Phase Increment Value parameter indicated by the wizard to get the desired frequency I hope this helps you Regards, Thiago
