8 years agoMysterious trouble sharing FPGA RAM with HPS
Hello all I'm a hobbyist and I'm trying to learn verilog and FPGA design by building a PDP-8 simulator. I've built the verilog for the PDP8 and it passes all the test code when run on a simulator....
Daixiwen
8 years agoSorry I'm not familiar with Linux on the SoC platform. I hope someone else can answer that. Can you find any code examples for the HPS platform on Linux? If you find any code sample with a DMA it should be in there, it is also a common problem when dealing with DMAs.
