17 years agoMy FPGA is not detecting the XOR edge..
I have this verilog code, which depends on either the posedge of the clock or the XOR of my data with its delayed version. assign x1 = data;
assign x2 = ~x1;
assign x3 = ~x2;
assign XORData =...
17 years ago --- Quote Start --- Jake --- Quote End --- Yes its for the same issue. Thanx for the reply. Your first suggestion is OK for me. But about the second one, here is what I understood from your reply: The synthesis tool is clever enough to know that the inverters I am using r actually dummies, so it actually removes them. So I have to tell the synthesizer to KEEP those gates. Right? I am working on 5Mbps rate and I am receiving with 40MHz clock. I am keeping the Nyquist rate by having 8 times faster clock. So how many inverters do u advice me to use, ofcourse with KEEP? How would I make a long enough pulse for my XOR signal?
