17 years agoMy FPGA is not detecting the XOR edge..
I have this verilog code, which depends on either the posedge of the clock or the XOR of my data with its delayed version. assign x1 = data;
assign x2 = ~x1;
assign x3 = ~x2;
assign XORData =...
17 years agoWell it looks like you are still trying to resolve the same issue you were with your previous post. Let's start with the problem. You've got this input signal data and you want something to occur whenever there is a rising or falling edge transition on the signal correct? If I remember correctly it has something to do with a counter that you want to reset to 3.
Anyway, what is the edge rate of the data signal? Is the edge rate of the signal faster than your clock? By far the most typical method we use for edge detection is to register the input signal on every clock and compare the current input value to the last input value. e.g.input din;
reg din_r;
wire flag;
assign flag = ^{din,din_r};
always @(posedge clk) din_r <= din; Obviously this only works if the sampling rate obeys the Nyquist criteria. Your sampling clock must be at least twice the data rate of what your trying to sample (the edge rate of your data signal). Now if you want to continue to purse your current approach, you can try using the "keep" attribute on your not gate signal declarations as FvM as indicated. (* keep = 1 *) wire x2; (* keep = 1 *) wire x3; The synthesis tool is smart enough to figure out that the delayed signal you've created is equivalent in logic to the original signal. Therefore, it completely does away with what it considers to be your silly NOT gates. Now if you put the keep attribute in, it tells the synthesis tool that they are not in fact silly gates but you intend them to be there and the synthesis tool will leave well enough alone. However, you will likely not get a long enough pulse with a delay of only two NOT gates unless you can force the fitter to add a significant routing delay between them or by placing them manually in the fabric. Jake
