8 years agoMy FPGA design looking for new home.. Altera FPGA?
Hi guys. I have a couple different questions regarding Altera FPGA and environment. So I am looking for the easiest path to moving a design presently running on Spartan3AN, into another FPGA ...
8 years ago --- Quote Start --- Hi, You may want to look at the Max10 FPGA family as these also come with ADC and can be more than enough to work for your design. https://www.altera.com/products/fpga/max-series/max-10/overview.html --- Quote End --- Thanks, eapenabrm. I am about to order the Terasic a Max10 NEEK . I am hoping i can modify existing example code to have the Max10 NEEK accept an external master audio clock. Unfortunately, Terasic is out for two weeks, so i'm hoping to find out a little more before i select my solution. - do you happen to know if i will be able to change audio clock sources without issue, on the max10 neek? i imagine it is straight forward in principle - i'll just need to change the mclk factor from 256x or 512x or... to what i need to obtain codec 48khz. from 49.152mhz. external master clock. If no one knows i will take a chance that it won't be too difficult, but all comments welcome. If all else fails i could probably modify the evaluation board. Thanks. Cheers,
