9 years agoMy confuse about the Cyclone IV GX transceiver.
I want use the EP4CGX15F14 to implement 2 1000BASE-X ethernet.
But I am confuse about the clock networks.The EP4CGX15F14 has only one transceiver block GXBL0,There are 2 channels in the block. My understanding is that the 2 rx channel use the CDR respective, the 2 tx channel use 2 MPLLs in the FPGA.So I should feed 2 reference clocks to the pins. Is it right?No RepliesBe the first to reply
