17 years agomutex with onchip memories?!
hi, it is possible use one mutex by one processor to access multiple onchip memory. otherwise it is possible access theses memories through one mutex. if it is possible, how can i do this. b...
17 years agoI still don't understand... if you have only one CPU and several onchip memories, you can just connect everything together without any mutex and it will work.
Or do you have another component that can access those memories at the same time than the CPU?
