14 years agoMultiplication Rounding
Hey guys, I am multiplying two 32 bit numbers using LPM_MULT. Each number is in Q16.16 fixed point format. The product is a 64 bit Q32.32 number. I then shift the product to the ri...
14 years agoThanks for the reply Kaz. My concern was that the fractional part would cause the product to be huge. For example, if you have 111.010=7.25, it can be interpreted as 111010=58. Performing a rounding on a rather small number like 7.25 with a fraction might be the same as performing the rounding on a large number. Basically, I'm afraid that such a rounding algorithm would cause small numbers to become rounded as large numbers.
Another concern is whether I should even shift at all after multiplication. Anytime you multiply a number you get 2*N decimal places, where N is the number of decimal places in the inputs. Since I only want N precision, I would the product by the right by N bits to discard them. With the method you gave, do I even need to do this at all? Would it be better just to round only? I know this question may seem kind of stupid, but I'm still learing about fixed point for the first time.
