15 years agoMultiplication by 0,6
Hi i have an input of 8 bits and i need to make a multiplication by 0,6. I doesn't has to be precise so i thaught to do : INPUT * 19 /32 This is not a working code but is displays wh...
15 years ago --- Quote Start --- You're apparently describing the RTL netlist. To see, how it's synthesized, you have to examine the gate level. I also guessed, that a hardware multiplier would be inferred. If you have plenty of them, there's nothing against it, I think. Otherwise you would specify multstyle "logic" for the respective node. --- Quote End --- I did go down to the Technology map viewer, they are different, but in the end there is no hardware multiplier used (as witnessed in de Flow Summary). I guess the mapping and fitting are able to deal quite well with the 'one operand' being a fixed value. --- Quote Start --- If it was me I will also add a further 16 to the list of addition, so I get rounding up at truncation --- Quote End --- We have to make a choice here: floor (== truncate) : what is in the example code ceil : should add 31 (and then truncated), or better said add 2^n - 1 financial rounding : like kaz proposes adding 16 or 2^(n-1). This looks interesting ...
