15 years agoMultiplexer Output Glitching
Hi all, I'm having trouble multiplexing a number of signals without the output glitching. The following 4 to 1 multiplexer with all the inputs connected to 1 shows the issue: module mult...
15 years agoThanks for having a play josyb, it is appreciated.
I've tried all sorts of arrangements for the 4 to 1 (though not yours...) and all suffer from the same problem as I would guess that they synthesize into the same thing. I now have a solution that appears to work (see above) but I am not sure that it is guaranteed to work as I don't understand the mechanism as to why it is glitching. Putting in delays may well cure it but again I'm not sure it is a robust solution. If you change the testbench code to the following then I would expect glitching as two inputs are changing at once and it transits through a state with a different output. Interestingly, this produces glitches that are 7ns in size compared to the 1ns glitches I was seeing initially.`timescale 1 ns / 100 ps
module multiplexertest_TB ();
reg a,b,c,d;
reg s,t;
wire q;
multiplexertest multiplexertest_inst
.a(a) , // input a_sig
.b(b) , // input b_sig
.c(c) , // input c_sig
.d(d) , // input d_sig
.s(s) , // input s_sig
.t(t) , // input t_sig
.q(q) // output q_sig
initial begin
a = 1;
b = 0;
c = 0;
d = 1;
s = 0;
t = 0;
end
always begin
# 40 t = !t;
s = !s;
end
endmodule
