15 years agoMultiplexer Output Glitching
Hi all, I'm having trouble multiplexing a number of signals without the output glitching. The following 4 to 1 multiplexer with all the inputs connected to 1 shows the issue: module mult...
15 years agoFrom the Quartus Help:
--- Quote Start --- You can use this synthesis attribute to keep a combinational node so you can observe the node during simulation or with the SignalTap II Logic Analyzer. --- Quote End --- I interpret this that the Fitter/Router will 'keep' said wire/signal but it will not prevent the Fitter/Router from placing it differently on a subsequent compile. --- Quote Start --- But at least, when more than one module input signals are changing at the same time, it can't work any more. --- Quote End --- Isn't that the nature of an asynchronous circuit? To Bat Technologies: You have created a two-step solution which you can assess by viewing your design in the RTL Viewer. Before my first reply I first tried a few things in Quartus myself and rewrote your equation into a single step one. I add the code for your perusal:module multiplexertest (
input wire a,b,c,d,
input wire s,t,
output wire q , q2
assign q = (s) ?
((t) ? d : c) :
((t) ? b : a);
assign q2 = !s && !t && a
|| !s && t && b
|| s && !t && c
|| s && t && d
endmodule At first compile q2 was as glitchy as q. I then added a 5.000 ns tpd (for a CycloneII auto device) and then q2 becomes glitch-free. But I'm not sure whether this will stay this way.
