15 years agoMultiplexer Output Glitching
Hi all, I'm having trouble multiplexing a number of signals without the output glitching. The following 4 to 1 multiplexer with all the inputs connected to 1 shows the issue: module mult...
15 years agoOk, I've been playing some more and have used three 2 to 1 multiplexers to create the 4 to 1 and have used the /* synthesis keep */; trick (thanks FvM) so that the 2 to 1 mux's don't get reduced. This now seems to work as I require i.e. it is glitch free so it solves my problem. However, I still don't understand why my original code glitches. If two inputs changed at once, I could understand the glitch if the output from only one input change was different but this isn't the case.
module multiplexertest (
input wire a,b,c,d,
input wire s,t,
output wire q
wire x,y /* synthesis keep */;
assign x = (t) ? d : c;
assign y = (t) ? b : a;
assign q = (s) ? x : y;
endmodule
