10 years agoMultiple synchronous clocks and PLL in digital audio application
I am about to make a digital audio transceiver in a Cyclone V device and I am a little bit stuck on the clock strategy (and slightly rusty): On the receiver the data is synchronized on a input ...
10 years ago --- Quote Start --- Given that there are plenty of PLL output counters, you could just use the same PLL to generate 3 clocks, each at the required frequency (256,128 and 64 * fs). Because they all come from the same PLL, the output counters are basically doing what a clock enable would do, producing synchronous clocks at the required frequencies. --- Quote End --- Yes PLL is an option but in my opinion is an overkill remembring issues of lock, simulation, upgrading design, readability ...etc. you can generate divide by 2 based on inverter:
process(clk)
begin
if rising_edge (clk) then
en1in2 <= not en1in2;
end process;
