10 years agoMultiple synchronous clocks and PLL in digital audio application
I am about to make a digital audio transceiver in a Cyclone V device and I am a little bit stuck on the clock strategy (and slightly rusty): On the receiver the data is synchronized on a input ...
10 years ago --- Quote Start --- That is no problem, very slow in comparative sense and you should achieve fmax in cyclone V readily. So I will go for one clock system. generate enable at 1/2 and 1/4 rate and apply clcok to every process together with its enable. Do not gate the clock to divide it. --- Quote End --- Thank you. Something like this does not gate the clock, right: (Again my HDL is rusty from years of pause)
-- Generate 1/4 rate enable
DIV : process (clk)
begin
if clk'event and clk='1' then
enable <= 0 when enable=3 else enable+1;
end if;
end process;
FSM : process (...)
begin
if enable=0 then -- Progress the FSM
next_state <= ...
else -- Keep the current state
next_state <= state;
end if;
end if;
end process;
