14 years ago
multiple constant drivers
i need help, can anyone help me which registers should be removed so that multiple constant driver error would be removed.
thanks
    You are assigning those registers in two different processes.
    These assignments should be made in a single 'always @' process, otherwise this would mean multiple drivers from the synthesizer's point of view.
    the error is in the posedge clk for the counter. it says multiple constant driver error for counter, count_done and count_done1.
    What is the error you are getting exactly? (Quartus normally tells you which line or what signal name has the multiple driver error)
