12 years agoMulticycle custom instruction repeated calls, hangs, signals
Hello, I have some problems with a multicycle custom instruction. I'm using a Terasic DE1 board with Quartus II 13.01 64 bit on Ubuntu 12.04. I've started with the NIOS II system for "count...
12 years agoThe sopc builder software used to cache the timestamp (or similar) from the board instead of re-reading it.
Quite possibly something similar still happens. It is a shame that the Altera eample about using custom intructions just tells you how to click the buttons to add/remove the ones they supply. The source for one that implements add would be more useful! I wrote a combinatorial one that uses the 5 bit rB field to choose between various bit and byte reversals.
