12 years agoMulticycle custom instruction repeated calls, hangs, signals
Hello, I have some problems with a multicycle custom instruction. I'm using a Terasic DE1 board with Quartus II 13.01 64 bit on Ubuntu 12.04. I've started with the NIOS II system for "count...
12 years agoI'm pretty sure "DONE" needs to be asserted for a single clock only.
The NIOS is probably hanging prior to issuing the next instruction because it's waiting for "DONE" to be de-asserted? I don't think you have to do anything special with "RESULT" when you clear the "DONE" bit (it can keep it's old contents).
