12 years agoMulticycle custom instruction repeated calls, hangs, signals
Hello, I have some problems with a multicycle custom instruction. I'm using a Terasic DE1 board with Quartus II 13.01 64 bit on Ubuntu 12.04. I've started with the NIOS II system for "count...
12 years agoI have litte, very little experience in Nios II but I tell you what I learn with trial and error method. When you place a Nios processor in SOPC builder you have an CPU ID option. Click on it. The USB Blaster don't establish a good link with your processor without this.
Place a system ID component in SOPC builder. With this you avoid the sys ID mismatch but ignore the timestamp mismatch ID when you download the firmware ( unless you have a timer component for timestamp activities ). I see you vhdl code. I assume it is not a testbench, so why do u use metavalue U?: RESULT <= (others => 'U'); -- *** DONE <= 'U'; -- *** this is intended only for simulation. It has no sense in synthesis. Assign ( others => '0' ) or something like that to RESULT when reset take place.
