MT25Q256 replacement for EPCQ256 write issue
- 7 years ago
I've resolved the issue. We were using an old version of the ASMII Parallel 2 that had somehow gotten ported across into the 18.1 software. By removing the ASMII Parallel 2 IP and replacing it with a new instance of the IP (which reported as ASMI Parallel 2 Top) we were able to talk to the MT25Q properly.
Hi RLyon,
I had the same problem with Arria 10 and the Serial Flash Controller IP replacing an EPCQL256 with a MT25QU256. After I replaced the Serial Flash Controller in QSYS with Generic Quad SPI Controller II writing tho the flash works again.
For that you have to use an other API function (alt_qspi_controller2_write) .
Jens
Sounds like Altera didn't update the combined ASMII controller IP properly. I'll see if that workaround will work with our solution.
EDIT: Are you using NIOS? We're communicating with the device through a Linux driver which we'd rather not change if possible.
