13 years agoMSEL wrong configuration
Hello, I designed a board using a EP4CE22F17C6N and I made a wrong connection on MSEL. I put it on MSEL[2..0] 001 instead of MSEL[2..0] 010. Besides the high level is tied to VCCio e.g 3,3V in...
10 years agoHi,
I have found that the wrong MSEL connections were causing this issue: "Error (209014): CONF_DONE pin failed to go high in device 1". Cyclone IV E, MSEL[2..0] = 001 was not overwritten by JTAG connection. Therefore JTAG was unable to program the device. Maybe the datasheets should reflect this. After correcting the MSEL[2..0] = 010, the JTAG became responsive. Regards, James.
