17 years agoMSEL setup with Cyclone III part
Hi, We are working on a board including a Cyclone III FPGA. The MSEL pin belong to bank 6 which VCCIO in our design is 1.8V. Is it still valid to use a 2.5V voltage with this configuration ? If...
17 years agoI did'nt find this quote in the document you linked.
It says that the MSEL pins should be connected to ground or VCCA (2.5V), so it's independent of the bank VCCIO. On the other hand the signals to the configuration device use the VCCIO levels of the bank they are in.
