10 years agoMonitoring Output from Cyclone IVGX
Hi I have a CycloneIVGX board (Onboard a Terasic De2i-150) and the problem I have encountered seems a very novice (nonetheless). I have a simple counter module that is continuously generating output ...
10 years ago --- Quote Start --- Didn't know about either. Will definitely give it a try and revert back!! Thanks!!! --- Quote End --- How did you make out with your research into the logic analyzer? I think you will find that the best thing to do is learn how to use the built in free Signalink logic analyzer. Regards, Kevin
