8 years agoMonitor wires inside module region ModelSim in gate -level or timing simulation
While doing gate-level simulation, i found an output miss-match in my design. I want to investigate it further but all the wire in module.vo files, that was previously assigned in module.v, was renam...
8 years agoThere's a separate window view in ModelSim I'm talking about where you drag and drop from. I wish I had the tool open right now, but I think it's the Object window (kind of a purple background). When you select one of the modules you list here, the Object window displays the signals in that module.
