14 years agoModelSim with VHDL 2008
Peace be upon you; I am using Quartus II 11.1, ModelSim 10.c (x64), I am used to design my files on Quartus and simulate it on ModelSim using VHDL 2002; Then I had to move to VHDL 2008 due to so...
14 years agoI am trying to create a generic register file
{ Generic Width Generic number of registers Generic number of Read/Write Ports } I could achieve this by using a 2D array : Type 2D_Array (Natural Range<>, Natural Range <>) of STD_LOGIC ; But this way caused trouble when I use it because when I try to use the register file as a component, I have to deal with its Read/Write Ports as a 2D array, so it would be a lot easier to have an array of STD_LOGIC_VECTOR instead. A constant in a package restricts the use of the register file as I use it a lot with variable parameters.
