14 years agoModelSim with VHDL 2008
Peace be upon you; I am using Quartus II 11.1, ModelSim 10.c (x64), I am used to design my files on Quartus and simulate it on ModelSim using VHDL 2002; Then I had to move to VHDL 2008 due to so...
14 years agothe altera version is the limited version of modelsim, provided by altera, and is released every so often (probably about every 6 months)
The PE version requires a separate licence. But it allows mixed code simulations. The SE version is even more expensive but has a 64 bit version for increased memory requirements and a lot of other gubbins people dont use. So I guess you're stuck until Altera release a new Modelsim ASE. Could you actually explain what you are trying to do? Could you not replace the generic with a constant in a package?
