17 years agomodelsim vsim-3601 on counter
Hi folks- The following code returns in modelsim a # ** Error: (vsim-3601) Iteration limit reached at time 0 ps. when I run the simulation. However, when I step through the program, I se...
17 years agowangahrah - you're right look through your loops in your testbench. This sort of thing usually happens when you get a self referencing loop with no time delay in it.
Taking Daixiwen's testbench, another way of writing the first process would be: clk <= not clk after 5 ns when stoptest /= '1'; (provided clk has an initial value in its declaration). if you mistyped it e.g.: clk <= not clk when stoptest /= '1'; then the concurrent statement would keep getting called to invert the clk without ever advancing simulation time (and you'd probably get the same error message that you got).
