10 years agoModelsim error
Hii i am using Modelsim student edition for the simulation of my edge detection code.
I am getting the following error.... ** Error: fixed_pkg Unbounded number passed, was a literal used?** can any one please suggest what is the meaning of this error??? Thanx and regards!!13 Replies
--- Quote Start --- Very little information to go on: What version of modelsim? what version of fixed_pkg? post some code? --- Quote End --- Sorry for less information...I am using model sim 10.4a PE student version.And fixed_package is of $Revision: 1.11 $ version. Actually my code is of 877 lines so its not possible to paste the complete code.Also I am having two more modules with it. It is showing error in the following process .. angle1: process (clk) variable index2 :integer:=0; variable index3 :integer:=0; variable count1 :integer:=0; VARIABLE row_cnt_m: INTEGER:=0;--row count VARIABLE col_cnt_m: INTEGER:=0;--coloumn count VARIABLE col_tr_m: BOOLEAN:=FALSE;--end of coloumn begin IF(clk'EVENT AND clk='1') THEN mod_d <= unsigned(to_ufixed(resize((abs(dx)+abs(dy)),7,0))); --Resize the result to 8 bits buffm(index2)<=(mod_d); index2 := index2+1; col_cnt_m := col_cnt_m +1; count1 := count1+1; --at end of one row IF (count1=256) THEN row_cnt_m:=row_cnt_m+1; IF (col_tr_m=FALSE) THEN col_res_m<=col_cnt_m; col_tr_m:=TRUE; END IF; count1 := 0; col_cnt_m :=0; END IF; --at end of one frame IF (index2=65535) THEN row_res_m<=row_cnt_m; row_cnt_m:=0; col_cnt_m:=0; index2:=0; count1 := 0; END IF; IF (row_cnt_m=3) THEN prv_load_m<='1'; cur_load_m<='1'; nex_load_m<='1'; END IF; IF (dx /= "000000000000000" ) THEN IF (dy /= "000000000000000" ) THEN div <= resize((dy /dx),8,-3); END IF; END IF; if ((num1 < div AND div < num2)or( num5 < div AND div < num1) ) then data <= my_lut(4); elsif (num2 < div AND div < num4 ) then data <= my_lut(1); elsif ((num4 < div AND div < num8) OR (num7< div AND div < num6) ) then data <= my_lut(2); elsif (num6 < div and div < num5) then data <= my_lut(3); end if; bufang(index3) <= data; index3 := index3 +1; if (index3 =65535) then index3 := 0; end if; END IF; end process angle1; I am taking a 256 * 256 image.And this is the part for angle calculation in canny edge detector.my_lut is a lookup table having values 0 ,45,90 and 135 in degree.and variable num is different variable range in sfixed formate. - Altera_Forum
What version of modelsim? what version of fixed_pkg? post some code? - Altera_Forum
Why would you think anyone will know what's wrong when you didn't include any code?
