15 years agoModelsim: compiling into libraries
Hi all, I've a few questions regarding Modelsim: 1) libraries contain the VHDL files or the result of the compilation of these files? 2) How can I compile a file in a directory by my ...
15 years agoVery good...that was the problem...sorry, i'm a newer in VHDL and Modelsim :)
but now I've got another problem...the last one: In one package, i've declared: package log_package is procedure log_write(level_i : in integer; from_i : in string; str_i : in string);procedure log_write(level_i : in integer; from_i : in string; bus_command_i : in t_bus_command);
procedure log_write(level_i : in integer; from_i : in string; bus_result_i : in t_bus_result); end log_package; ... so three procedures with the same name, but different input parameters; in my top I've written: entity top is ... end; architecture arch_top of top is ...<signals>... begin ... myprocess : process procedure writetestresult(test_name_i : in string; result_i : in boolean) is
begin
if result_i then
log_write(log_level_essential,instance_name,"passed " & test_name_i);
else
log_write(log_level_essential,instance_name,"failed " & test_name_i);
end if;
end procedure writetestresult; begin ... end process myprocess; end arch_top; Modelsim get me an error: ** Error: (vcom-1136) Unknown identifier "log_write". Where am I going wrong?
