15 years agoModelsim: compiling into libraries
Hi all, I've a few questions regarding Modelsim: 1) libraries contain the VHDL files or the result of the compilation of these files? 2) How can I compile a file in a directory by my ...
15 years agoThank you very much.
Now I've another problem: I've compiled a library into a folder with this command: vcom -reportprogress 300 -work lib_one c:/component.vhd Component.vhd contains this component: package clock_sim_package iscomponent clock_sim
generic
constant freq : integer:=10000000;
constant duty : integer:=50
port
enable : in std_logic;
output : out std_logic
end component;
end clock_sim_package; library ieee;
use ieee.std_logic_1164.all; entity clock_sim is
generic
port
end clock_sim; architecture clock_sim_arch of clock_sim is
begin
mainprocess : process
constant rduty : real:=real(duty)/100.0;
constant tclkh : time:=1 sec*((1.0/real(freq))*rduty);
constant tclkl : time:=1 sec*((1.0/real(freq))*(1.0-rduty));
begin
if enable='1' then
output<='1';
wait for tclkh;
output<='0';
wait for tclkl;
else
wait until enable='1';
end if;
end process mainprocess;
end clock_sim_arch; Into the top I instanciate the component (under architecture..begin): the_clock : clock_sim
generic map
duty=>50,
freq=>clock_freq
port map
enable=>'1',
output=>clk
); but when I try to compile the top, this is the answer: ** Error: Identifier "clock_sim" does not identify a component declaration. What am I doing wrong?
