12 years agoMissing Bytes reading FPGA data with FTDI 2232H
Hi, I recently developing an FPGA program that will be used to measure something. IO inputs will be stored in the FPGA SRAM and later transferred with over USB with the FTDI chip to be proce...
11 years agoHi, I am Bharat
I am using FPGA (1-ADC 2314 2- FPGA (spartan-6) 3- FTDI 2232 4- LabVIEW), FTDI 2232 module and LabVIEW for my project. My first aim is to establish simple byte reading from my board (ADC) As you have made FTDI controller, I would like to have some inputs from your side. Please help for following queries. I read FTDI datasheet, what I understood is: --it might not be possible to transmit single byte transfer using FTDI 2232 module (minimum - 64 bytes). is it correct ? --if possible, pl. share your complete code. (might be asking too much then sorry ) ---What is the purpose of C codes you are referring above ? thanks & best regards Bharat
