12 years agoMissing Bytes reading FPGA data with FTDI 2232H
Hi, I recently developing an FPGA program that will be used to measure something. IO inputs will be stored in the FPGA SRAM and later transferred with over USB with the FTDI chip to be proce...
12 years agoHere are my notes for the FTDI devices;
http://www.ovro.caltech.edu/~dwh/correlator/pdf/ftdi.pdf and I've attached a loopback example program. There's one comment in there that may be relevant to your problem ...
/* Set flow control per AN130 - apparantly this stops the
* driver from dropping data.
ftStatus = FT_SetFlowControl(ftHandle, FT_FLOW_RTS_CTS, 0, 0);
if (ftStatus != FT_OK) {
printf("Error: FT_SetFlowControl returned %d\n", (int)ftStatus);
return 1;
Ah, but I see you already have that line in your code. So perhaps your issue is with the interface logic. Look at the waveforms in the PDF I linked to. Use SignalTap II in your design to reproduce them. Perhaps you have an issue. Do you have a testbench that you have used to test your design? Cheers, Dave
