MIPI D-PHY transmitter on MAX 10 output buffers
Hello, thank you for your answer.
About OE. As written in AN745 to implement MIPI D-PHY with passive resistor network using Intel FPGA one needs to connect two single ended lines through resistors with differential lines. So when Lane in Low Power state, on both of these single ended lines will be a high level signal around 1.2V than will come right to lvds buffer. So i'm afraid that if this lvds buffer does not have anything like output enable signal, that will drive it's lines to high impedance state, it will disturb Low Power state or worse like burn down the internal circuits.
So my question was, in another words, how can i create D-PHY physics with passive resistor network? What kind of IO standard do i need to assign to my output pins and whether high speed pins should be tristated?
