14 years agoMinimum pulse width violation
Hey guys, I'm using the timequest analyzer. I first setup the clock using the wizard. 120Mhz. I'm using Cyclone II, C6. After performing compilation and checkin...
14 years agoLook wat all signals you have assigned in default you have to assign some value in each and every case otherwise it will definately give a latch.
Example always @ (x) begin case (x) begin s1: begin a=1'b1; // 2 signals in s1 b=1'b1; end s2: begin a=1'b0; // 1 signal in s2 end default: a=1'b0; b=1'b0; // 3signals in default c=1'b0; My reasoning is that each and every case should have eaqual signals which have been used or it will give a latch if even a single signal is unassigned in a case which has been assigned in other case.
