14 years agoMinimum pulse width violation
Hey guys, I'm using the timequest analyzer. I first setup the clock using the wizard. 120Mhz. I'm using Cyclone II, C6. After performing compilation and checkin...
14 years agoThanks for your help JK,
Here is the full error below:
-0.127 2.000 2.127 High Pulse Width fclk Rise circular_buffer:xncb|input_buffer:ib|altsyncram:altsyncram_component|altsyncram_g9r1:auto_generated|q_b
Some of the signals that drive the input of memory are inferred as latches by the compiler. Here is the code that drives the memory shown below:
always @(pstate)
begin
case(pstate)
s0:
begin //state 0 resets all control signals and aligns the read pointer of the
acc_reset<=0; //circular input buffer to the latest input sample. If the wrptr for the
rdptrw<=0; //input buffer isn't zero, then decrement the wrptr by one and set that
calc<=0; //equal to the read pointer. This is because everytime a new value is written
wn_w<=0; //to the input buffer via xn_w, then the write pointer automatically increments
if(wrptr !=0) //to the next location. Thus, one minus the current wrptr gives the location of
rdptr<=wrptr-1; // the most recent input sample.
else
rdptr<=(L-1);
end
s1:
begin
counter<=0; //reset the counter to zero since this is the first product of the convolution.
end //also delay by one cycle to accomodate memory latency
s2:
begin
rden<=1; //assert read enable to read first coefficient from memory. Also clear the accumulator.
acc_reset<=0;
end
s3:
begin
rden<=0; //now that the old coefficient is output, assert calc to calculate a new coefficient
calc<=1;
wn_w<=0;
end
s4:
begin
rden<=0; //increment the counter for the next multiplication
calc<=0;
wn_w<=0;
counter<=counter+11'd1;
end
s5:
begin
wn_w<=1; //store the new coefficient
end
s6:
begin
wn_w<=0; //output input value to begin multiplication
rden<=1;
end
s7:
begin
rden<=0; //perform multiplication and latch it in the MAC
mac_latch<=1;
if(rdptr==0) //if the current input sample is coming from the bottom
begin //of the input buffer, then wrap around to the top in a circular
rdptr<=(L-1); //fashion. Otherwise, just decrement the pointer.
end
else
begin
rdptr<=rdptr-1;
end
rden<=0;
if(!(counter==(L))) //if there are still more convolution multiplications left
begin //increment the read pointer to the coefficient buffer
if(rdptrw==(L-1))
rdptrw<=0;
else
rdptrw<=rdptrw+1;
end
end
s8:
begin
mac_latch<=0; //calculate the next coefficient
rden<=1;
end
s9:
begin
calc<=1;
wn_w<=0;
rden<=0;
end
s10:
begin
calc<=0;
end
s11:
begin //if there are no more convolution products to be calculated,
firdone<=1; //then convolution is finished. Assert firdone to indicate this condition.
acc_reset<=1; //also reset the accumulator for the next cycle.
end
s12:
begin
//wn_w<=0;
firdone<=0; //deassert firdone
end
default:
begin
rden<=0;
calc<=0;
firdone<=0;
acc_reset<=0;
wn_w<=0;
rdptr<=0;
rdptrw<=0;
counter<=0;
end
endcase
end
It is the output part of a state machine that operates a circular buffer. For some reason, I recieved these warnings that stated that some of the signals input into the memory were inferred as latches:
Warning (10240): Verilog HDL Always Construct warning at circular_buffer.v(196): inferring latch(es) for variable "rden", which holds its previous value in one or more paths through the always construct
Warning (10240): Verilog HDL Always Construct warning at circular_buffer.v(196): inferring latch(es) for variable "calc", which holds its previous value in one or more paths through the always construct
Warning (10240): Verilog HDL Always Construct warning at circular_buffer.v(196): inferring latch(es) for variable "firdone", which holds its previous value in one or more paths through the always construct
Warning (10240): Verilog HDL Always Construct warning at circular_buffer.v(196): inferring latch(es) for variable "acc_reset", which holds its previous value in one or more paths through the always construct
Warning (10240): Verilog HDL Always Construct warning at circular_buffer.v(196): inferring latch(es) for variable "wn_w", which holds its previous value in one or more paths through the always construct
Warning (10240): Verilog HDL Always Construct warning at circular_buffer.v(196): inferring latch(es) for variable "rdptr", which holds its previous value in one or more paths through the always construct
Warning (10240): Verilog HDL Always Construct warning at circular_buffer.v(196): inferring latch(es) for variable "rdptrw", which holds its previous value in one or more paths through the always construct
Warning (10240): Verilog HDL Always Construct warning at circular_buffer.v(196): inferring latch(es) for variable "counter", which holds its previous value in one or more paths through the always construct
Warning (10240): Verilog HDL Always Construct warning at circular_buffer.v(196): inferring latch(es) for variable "mac_latch", which holds its previous value in one or more paths through the always construct
Any help would be greatly appreciated.
