10 years agoMigrate from Cyclone V dev kit.
Hello All. After debug project on the dev kit (use ddr3 controller) i am want migrate to simple C5GT with different package and thoi little trouble for me. All pin assigments need add manualy...
10 years agoIt sounds like you are doing the right thing. Yes, you will definitely need to assign (or accept) pin locations changing between the two packages.
The P/N swapping sounds very strange - the tools are very good at identifying P/N correctly. How is this coded? I'm concerned how your design is captured and why Quartus wants to do as you suggest. Posting your top level design would help. Cheers, Alex
