10 years agoMigrate from Cyclone V dev kit.
Hello All. After debug project on the dev kit (use ddr3 controller) i am want migrate to simple C5GT with different package and thoi little trouble for me. All pin assigments need add manualy...
10 years agoHi Alex.
Thanks for answer. So i am use dev kit with 5CGTFD9 F35 pack, and want migrate to 5CGTF D5 F23 pack. In all cases before compile project for F23 pack i am remove assigments and look to result - after compile its looks not bad. One pin DQ[13] have not correct placement, dq[0]-[12] fine - i am check pin outs files and look to HMC part in this table. And next problem - diff pair pins - ALL inverted. EXACTLY clock_p after compile placed to clock_p(n). Thank you for understand.
