Migrate Cyclone to new device
- 3 years ago
Regarding the device recommendation, you may want to browse the device list here : https://www.intel.com/content/www/us/en/products/details/fpga.html
Cyclone legacy equivalent product is MAX10 or Cyclone V FPGAs.
regards,
Farabi
You can reload the design using updated Quartus version. Re-assign the device to the desired device part number, then compile. There might be some warning or error along the way for the Quartus software to compile and adapt from the older device, especially if you have older IP used in previous design. You will need to update the IP then the compilation will be successful. Final step, re-assign the IO pins following your pin assignment on the board design. Then recompile again for the new pin assignment take effect. If everything goes well, the design migration is 90% completed. You may want to proceed for timing analysis using Quartus tool TimeQuest Timing Analyzer.
regards,
Farabi
