8 years agoMicron configuration flash replacement
I've been using the Micron N25Q as an EPCS and the M25P as an EPCQ. Specifically the 128MBit 16 pin SOIC one. I'd like to make a new run of my boards and discovered the 'known compatible' Micr...
8 years ago --- Quote Start --- I appreciate the clarification from Intel. In my view the Intel strategy needs some refinement here. For your cheap lines of fpga chips the official flash chips are a very significant part of the BOM. The economics do not work. --- Quote End --- Hi, We recently used the following parts from Winbond and they work both the 64Mb (8 pin soic) and 128Mb (soic16). Enclosed is the part number for the 8 pin part (64Mb). We are using Quartus 16.1 w25q64jvzeiq (https://www.digikey.com/product-detail/en/winbond-electronics/w25q64jvzeiq/w25q64jvzeiq-nd/5803997) Thanks
