8 years agoMicron configuration flash replacement
I've been using the Micron N25Q as an EPCS and the M25P as an EPCQ. Specifically the 128MBit 16 pin SOIC one. I'd like to make a new run of my boards and discovered the 'known compatible' Micr...
8 years agoHi,
we cannot guarantee if using non-Altera (Intel PSG) flash devices such as Micron or Spansion or Cypress or Windbond will work successfully with our software tools and FPGA devices or not. For Active Serial configuration mode, we only support EPCS, EPCQ, EPCQA and EPCQL device flash memory. Thus you need to use EPCS, EPCQ, EPCQA or EPCQL flash memory devices for Active Serial configuration scheme on Altera (Intel PSG) FPGA devices. We have never mentioned promoting Micron or Spansion or Cypress or Windbond device officially support for Active Serial configuration scheme on Altera (Intel PSG) FPGA. We do not perform any testing or validation on these devices for Active Serial configuration mode. Thank you. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
