8 years agoMemory WRITING issue
Dear,
I have a procedure (Sort) that read two numbers in each cycle. and return the max and the min. I am reading two numbers from mif file , the problem is that I want to write back the result returned from the PROCEDURE to the same location of the memory that I had read from. I expected it to be in the next cycle but the memory is not able to be inferred " can't infer memory for variable 'ram1' with attribute '"M4K"'. I listed the code below as reference. Many thanks. ARCHITECTURE behave OF min_max IS TYPE MEM IS ARRAY(0 TO 15) OF signed(9 DOWNTO 0); signal ram1:MEM; ATTRIBUTE ram_init_file: STRING; ATTRIBUTE ram_init_file OF ram1: SIGNAL IS "bits.mif"; ATTRIBUTE ramstyle: STRING; ATTRIBUTE ramstyle OF ram1: SIGNAL IS "M4K"; SIGNAL reg1sig,reg2sig,dataodd,dataeven,minsig,maxsig: signed(9 downto 0); BEGIN PROCESS (clock) variable kk:integer range 0 to 7:=0; BEGIN IF rising_edge(clock) THEN dataodd <= ram1(2*kk+1); dataeven<=ram1(2*kk); reg1sig<=dataodd; reg2sig<=dataeven; Sort(Reg1sig,reg2sig,maxsig,minsig); -- THE PROCEDURETAKES TWO NUMBERS AND RETURN TWO , IT WORKS WELL WITHOUT WRITING TO RAM1 ram1(2*kk+1) <= maxsig; ram1(2*kk)<= minsig; kk:=kk+1; END IF; OUT<=maxsig; END PROCESS;12 Replies
You really need to study the document I provided. If your code doesnt match the template, then a ram will not be infered.
I did and I am still reviewing it. Thank you very much for your continuous help and notes.
