8 years ago
Memory WRITING issue
Dear,
I have a procedure (Sort) that read two numbers in each cycle. and return the max and the min. I am reading two numbers from mif file , the problem is that I want to write back the result returned from the PROCEDURE to the same location of the memory that I had read from. I expected it to be in the next cycle but the memory is not able to be inferred " can't infer memory for variable 'ram1' with attribute '"M4K"'. I listed the code below as reference. Many thanks.
ARCHITECTURE behave OF min_max IS
TYPE MEM IS ARRAY(0 TO 15) OF signed(9 DOWNTO 0);
signal ram1:MEM;
ATTRIBUTE ram_init_file: STRING;
ATTRIBUTE ram_init_file OF ram1: SIGNAL IS "bits.mif";
ATTRIBUTE ramstyle: STRING;
ATTRIBUTE ramstyle OF ram1: SIGNAL IS "M4K";
SIGNAL reg1sig,reg2sig,dataodd,dataeven,minsig,maxsig: signed(9 downto 0);
BEGIN
PROCESS (clock)
variable kk:integer range 0 to 7:=0;
BEGIN
IF rising_edge(clock) THEN
dataodd <= ram1(2*kk+1);
dataeven<=ram1(2*kk);
reg1sig<=dataodd;
reg2sig<=dataeven;
Sort(Reg1sig,reg2sig,maxsig,minsig); -- THE PROCEDURETAKES TWO NUMBERS AND RETURN TWO , IT WORKS WELL WITHOUT WRITING TO RAM1
ram1(2*kk+1) <= maxsig;
ram1(2*kk)<= minsig;
kk:=kk+1;
END IF;
OUT<=maxsig;
END PROCESS;
    You really need to study the document I provided. If your code doesnt match the template, then a ram will not be infered.
    I did and I am still reviewing it. Thank you very much for your continuous help and notes.
