17 years agoMemory Use Question
Hello Everybody! I don't know if this is the right section to ask this, if not please do excuse. I' a student working on the development of a circuit, using VHDL language, and the target it's...
17 years ago --- Quote Start --- Hi, ram size is 256*8 bits = 512 * 4 bits and so cleanly fits 4 M512 blocks. all your fifos are too large for M512 and it makes sense to use M4k for example the smallest fifo of 512*23 will fit cleanly 23 of M512 blocks or will fit 3 of M4k blocks with 512 bits wasted !!! I am a bit disappointed it seems your compiler didn't follow my claim about wasting. It didn't mind that and was more concerned to hold on to the graininess just in case. --- Quote End --- Hi, you mentioned that you use Synplify for synthesis. I assume you mean SynpifyPro. If memory usage is an issue in your project, youn can guide SynplifyPro which type of memory should be used for the implemention, by setting a syn_ramstyle attribute in the SDC file. Kind regaeds GPK
