18 years agoMemory map cannot fit?
I have written my own interface to a SDRAM and trying to add it i SOPC builder as an avalon tristate slave. The component is created without any error messages, but when adding it to my SOPC system I...
18 years ago1 - The maximum addressable space for NIOS is 31 bits. This is because NIOS uses the highest bit as cache bypass signal.
2 - If you do use all 31 bits of address space, you will have absolutely no room for any other components in your system. Jake
